Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: YAYPINTOS on April 10, 2014, 08:36:37 PM
Title: turbo or SC
Post by: YAYPINTOS on April 10, 2014, 08:36:37 PM
What is cheaper to install, what is better, and can they be installed on the stock 2.3l
Title: Re: turbo or SC
Post by: poomwah on April 10, 2014, 09:01:33 PM
neither would be a good choice on the stock 2.3 because the normally aspirated uses cast pistons instead of the forge pistons on the turbo.  Putting the turbo on an engine with cast pistons will probably melt the pistons.
Post by: YAYPINTOS on April 10, 2014, 09:53:05 PM
if i where to get the forged pistons would it be ok?
Post by: Pinto5.0 on April 10, 2014, 10:45:45 PM
Since Ford was kind enough to supply Pinto owners with plenty of factory 2.3 turbo engines in Tbirds, Mustang SVO's & Xr4ti's that bolt right in & are sporting forged pistons & everything you need to double or triple HP over a stock Pinto there really is no reason to build your own from scratch.
Post by: YAYPINTOS on April 10, 2014, 11:01:04 PM
soo i would need more than just forged pistons?
Post by: Pinto5.0 on April 10, 2014, 11:29:29 PM
Yeah, a turbo head has a D shaped combustion chamber as opposed to the Pinto heart shape. A turbo block is tapped to feed & return oil to & from the turbo. A whole turbo engine can be had for a few hundred dollars while good forged pistons can run double that.
Post by: YAYPINTOS on April 11, 2014, 12:06:23 AM
gotcha, do u know where i could find a turbo engine or even just a bigger engine then the stock that would still bolt right up?
Post by: Pinto5.0 on April 11, 2014, 12:36:19 AM
Craigslist has been my best source
