Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: Pintocrazed on August 09, 2014, 02:12:37 PM
Anybody know if I can use 74 up rotors on my 73?the 73 rotors are crazy expensive
Plain and simple, NO.
:( I didn't want to spend 300 for rotors
See bbobcat75's link for the differences in the rotors. Rockauto is a little cheaper at $222 plus shipping for two ACDELCO 73 rotors. Maybe put an ad in the wanted section. Good luck.
http://www.fordpinto.com/pinto-faq/71-spindle-to-74-spindle/msg130024/#msg130024
What does the "hub reg" dimension refer to?
Do you live near a self service yard? The local Pick Your Part has rotors listed at $14.99 with a $3 core charge. Probably $20 each out the door. On the 50% off sale day about $13 each. I know there aren't Pinto's every trip, but man, maybe I should be grabbing them when I can. If they Mic OK and aren't deeply grooved they are probably good. For the record I did get a spare set a number of years ago because people were complaining they were $100 each. Now $150!
Which brings up the subject..., can your rotors be turned? I think Pep Boys charged about $13 a rotor when I had my wife's Civic rotors turned. I opted to have them turned figuring the warping had run its cycle. I felt new rotors would just warp again. So far 9 months later everything is good.
I was thinking that it might be fairly trivial to machine the 74+ rotors, but I have access to a machine shop. 8) Not everyone does.
I believe the "hub reg" refers to OD of the rotor hub where the factory steel wheels center themselves on the rotor. I do know that the early factory steel wheels will not fit over the larger later year rotor hubs.
As far as machining a later year rotor down, I would have a concern with the later rotor "min thick" being larger that the early rotor "nom thick".
Since you are considering non-stock set up, this link shows how to install larger 5 lug rotors on the early spindle plus some other custom ideas. Note, larger rotors usually require larger wheels.
http://www.fordpinto.com/pinto-faq/front-disc-brakes-(4-5-lug)/msg6498/#msg6498
This is as cheap as you can find
http://www.amazon.com/ACDelco-18A1400-Professional-Durastop-Front/dp/B000C9HAJ8/ref=au_as_r?ie=UTF8&Make=Ford%7C54&Model=Pinto%7C693&Year=1972%7C1972&carId=001&n=15684181&s=automotive&vehicleType=5 (http://www.amazon.com/ACDelco-18A1400-Professional-Durastop-Front/dp/B000C9HAJ8/ref=au_as_r?ie=UTF8&Make=Ford%7C54&Model=Pinto%7C693&Year=1972%7C1972&carId=001&n=15684181&s=automotive&vehicleType=5)
If that's the case, then turning the hub diameter down to the early size wouldn't be hard. Pretty common with Granada brake swaps going onto early Mustangs.
That's a definite consideration if the vent passages are wider in the later rotor....and they probably are to save weight and material.
I didn't take a micrometer to them but I've had early & late rotors side by side & the vents appear similar in size. Cutting late rotors down to work on an early car should leave plenty of material.
