Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: Cookieboystoys on June 09, 2013, 06:26:31 AM
anybody know the door data plate codes for rear ends? door plate says 7
1979 Bobcat
I can't say for sure on a '79 but I have this for '73-'78. NOTE!! code 7 for '71-'72 is different - 3.18 non-locking.
? 3.40 ? I didn't think they offered that except for 1973 in a pinto? maybe I can jack it up and read the tag.
door plate says 7
Opps! My Bad.... code is an 8 not 7 which at 2.78 sounds right for a 4 spd 79 pinto/bobcat, autos had 3.08 and I have one of thoes too.
While the post isn't 8" specific, the title is enticing. So I'll throw this out for anyone interested. I believe only the 3.00, 3.40 and 3.55 were available for the 8" rearend. Some of the ratios seem to cross over between the 6-3/4" and the 8" (3.40 seemingly one of them).
Every time I go to Pick A Part (monthly - Sun Valley, CA) I check the 8" rears. The majority sadly have the center sections already pulled. There is one guy who at a minimum goes through weekly and pulls them all. Virtually all are 3.00 and a few 3.55. When I did my turbo swap I opted for the 3.00 thinking the Pinto was lighter than the Turbo Coupe and the 13" or 14" tires would work well. Ahhh..., not so much.
Ideally I think 3.25 would be best with shorter 13"-14" tires. But that ratio is limited to only a few older Fords. Otherwise it is the price of aftermarket gears and setup. So my quest is now for 3.40 as a compromise. If your running 16" tires you might get away with 3.55. Please note these ratios are referenced to daily driving.
Tom
