Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: dennisofaz on February 28, 2018, 11:52:11 AM
Hi, I have a 74 Runabout with a 2.3 and I need to know what the point gap souuld be, and what the fuel pump pressure should be. Thank you in advance!
Dennis
Point gap is .027 with dwell reading of 35-41 degrees. Timing is 6 degrees BTDC vacuum hose disconnected at distributor. Idle 850 rpm standard 750 auto in Drive. Plugs AGRF-52 gap is .034. Fuel pump pressure between 3.5-4.5 lbs and volume would probably run around a pint in 20 seconds. Total timing advance should approach 47 degrees. Base 6 degrees, centrifugal advance 32 degrees, vacuum 4.3 degrees. You should see total centrifugal at 4700 rpm. I pulled all this information out of a 1974 Motor auto repair manual. A little more information than you asked for but since I had the book open thought I might as well list it for you.
Hi nnn0wqk, Thank you very much for the information! I will try a 4-7lb electric fuel pump and see how it goes!
Dennis
