Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: 1972 Wagon on February 07, 2017, 12:57:12 PM
Can someone identify this part? It is in a bundle of wires that run along the fire wall and end above the master cylinder. I have checked my books and can't find a picture. Thanks
It's been awhile since I owned an automatic Pinto but I do remember a plug like that heading down to park/neutral safety switch. Is car an auto or stick? If stick it might not be used.
if she has a manual trans it could be the backup light switch , if it had more wires on it it would be an auto trans , but since it is unpluged the starter would not work , (unless it was bypassed ) way to check is to put the car in reverse and turn the key one and see if the backup lites work , if they do she might have A/C and some had a kicker that speed up the engine when you turned on the A/C , most over the years have disepered :o
The car is an automatic with factory installed A/C. The backup lights work. I had not driven the car for many years and finally got it back on the road. I can't remember if the connector was like that in years past. My 90 year old dad (original owner) can't remember what it was for either. I figure someone else might have a better memory!
Ok then it has to be kicker , it's for when you turn on the A/C it speeds up the engine (or keeps it from dying) a tad , you have to use a volt meter to test it to find out , when the A/C clutch is engaged you should have voltage on one of the wires , been years since I have seen one , the newer ones used vacuum to do the same thing , hope this helps , Later Blane in Mississippi 😇
Ur right, more likely back up switch.
