Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: righthandman on September 05, 2014, 03:01:13 AM
OK guys I know I've already read this here a time or two, but I actually need to know now and memory is shot. #1 is the 8" from a MII the same width and a exact bolt in. & #2 how do you tell a posi from the rearend tag on these. Thanks in advance
First question is yes, as long as you use the Pinto shock mounts/leaf springs. You can use the II shock mounts if you want to change shocks, but the II leaf springs will not work on a Pinto.
Can't help with the second.
