Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: Reeves1 on May 04, 2012, 04:59:52 AM
(http://img.photobucket.com/albums/v140/DerrickJB/My%201972%20Pinto/100_99981.jpg)
You can see in the picture above how the original builder welded a hump in the pan to go over the stering rack.
I'm going to lower the rack & weld the pan back to normal.
Never did like that hump, as it will hold oil back as well as hold "gunk" .
Car is a 72. Anyone lower a rack before ?
Anyone see a reason to not lower the rack ?
I know I will have to change the rag joint out. Going with a smaller dia. knuckle type joint. If I have to, I'll also notch the cross member for this, to get it low enough to clear the pan.
I do not have those headers, seen in the picture. I am having new headers made.
I lowered mine 2" on a '76 which has a different type of mounting. Your's looks easier to do as far as that is concerned.
I had to lenghten my steering shaft. I went with a u-joint style joint on both ends.
And there is the 'issue of bump steer' I found out to late that they make kits to overcome that.
You may want to contact 71pintoracer. I believe he has done that on his car. He has a lot of knowledge
with an early V-8 conversion.
Hi, On my v-8 swap I needed to replace the crossmember with a round tube. I used a 460 rear sump pan. after welding in a new crossmember I cut off the rack and pinion brackets and rewelded onto the new one. I think Its about 1" lower. I used a steering Knuckle from Flaming River Products for connecting the O.E. shaft to the Pinto Rack. I bought the knuckle from Summit. Have Fun.
For lowered racks, bumpsteer correction spacers: http://www.speedwaymotors.com/Bump-Steer-Spacer-for-Pinto-Spindle,35534.html (http://www.speedwaymotors.com/Bump-Steer-Spacer-for-Pinto-Spindle,35534.html)
or the entire "kit": http://www.speedwaymotors.com/Pinto-Spindle-Bump-Steer-Correction-Kits,52425.html (http://www.speedwaymotors.com/Pinto-Spindle-Bump-Steer-Correction-Kits,52425.html)
OK...just did a search for "bump steer". Not sure where those parts go.
Do I just put them on knowing the car will need them ?
Reeves.
The bump steer kits go on the bottoms of the spindles and take the place of the outer tie rod end or relocate it depending on the kit. While there is lots of info on correctly designing the whole deal using shorter inners to change the initial pivot points on the rack to match the line between the upper and lower arm pivots the important detail is you want to lower the tie rod end at the spindle in proportion to the rack . ideally the tie rod angle should be parallel with the suspension arms through the entire up and down travel. this should be sufficient to make it drivable without wanting to rip the wheel out of your hands
those spacers just lower the outers an arbitrary amount. to do it right get some of these
http://www.speedwaymotors.com/Adjustable-Tie-Rod-Adapter-Stud-to-Heim,3333.html
these
http://www.speedwaymotors.com/Precision-Male-RH-Heims,80.html
etc and then you can set it at the proper location
OhSix'
Thanks for the help ! Will get parts ordered.....
The second link is for a male type heim. I contacted them to see if they have the right ends for my car.
(http://img.photobucket.com/albums/v140/DerrickJB/My%201972%20Pinto/Rtierodend.jpg)
Parts in.
The adapter bolt is not even close to what I need: http://www.speedwaymotors.com/Adjustable-Tie-Rod-Adapter-Stud-to-Heim,3333.html
My tie rod is 1/2". The female heims come in 1/2 x 1/2 or 5/8 x 5/8.
They do not have a 1/2" tie rod end & 5/8" to fit the bolt.
Not to mention the tapered end for the spindle is 7/16" & mine is 3/8" (?)
Hard finding the right parts for a 72.
I've looked for up-dated spindles....no luck yet.
Disclaimer: not having done this, not sure what method would be easiest/best/safest. Also I do not know correct bump steer fixes. However it is easy to speculate like this.
The steering arm tapered hole on the 73 spindle is the larger size and should bolt in. An alternative would be to use a tapered reamer to enlarge the 72 hole. I do not know the angle needed, as they sell a couple different angle reamers. A local machine shop may be able to do it also.
As for the heim size mismatch, maybe make an adapter tube. Thread one end of a tube for the 1/2" tie rod and the other end for the 5/8" heim. Wrote to Flamming River who sells 71-72 racks and they said most people use a straight bolt to attach a heim to the spindle steering arm on race cars. Based on my measurements, the 72 spindle tapered hole could be drilled out to a straight 1/2" hole.
Since you are relocating the rack and have to make new mounts, maybe use a 74-80 rack. The member "fordmastertech" did this to a 73 Pinto, see link. The 72 spindle tapered hole would need enlargement for this. The linked photos no longer work but I saved most of them in Word (file too large to post here). If you want a copy, pm me your email address and I will send them to you.
http://www.fordpinto.com/general-pinto-talk/build-pics-1973-turbo-coupe/msg102503/#msg102503 (http://www.fordpinto.com/general-pinto-talk/build-pics-1973-turbo-coupe/msg102503/#msg102503)
I have a few ideas on what to do, but going to wait till my engine is back. I want to drop it in & see if just lifting the engine will work.
