Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: MitchiePinto on October 15, 2012, 05:36:21 PM
Currently I have a 2100 Motorcraft that is toast I rebuilt it and it runs but noticed after rebuilding it a vacuum leak coming from the throttle shaft output and there is lots of play in the shaft, latter found out that this is a common issue from wear and tear and requires a whole new carb.
I was given a 2150 off of a 318 and found it to run to rich and not idle so I removed the power valve and used a #16 power valve off the 2100 and it solved the issue but still not running right I noticed that it has external vacuum running off the power valve cover ? should I connect this to my manifold tee but theres gas running though there? is gas suppose to run under the power valve or should it be dry
Or should I just buy a Holley 350 cfm and order a restrictor kit and right sized PV and aluminum or rubber spacer
also what is the PV restrictor do? its sold from racer walsh and involves using a tap and drill bit? where exactly does it go and is it hard pricesion work? Will my car overheat with a Holley and is it fine for a standard transmission
I believe it leans out the mixture at an idle so you dont load up. I installed one in my 500cfm. It was pretty easy. Just make sure you drill straight. While i am still a little rich at an idle, it is much better than it was before.
Thanks for your comment, I think Il go with a holley 5200 re-manned from Napa just need the adapter plate
