Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: ToniJ1960 on January 23, 2012, 10:16:01 PM
The Lucas I put in my power steering has slowed the leaking a lot,but it still gets a little low after a while.Today I was driving and stopped somewhere to check it because it was whining a little, it didnt seem very low but I added 2 or 3 ounces. I think it was because it was so cold. After I added some power steering fluid it still did it for a little while then went away.
But there was foam or froth in the reservoir neck. What does this mean? Pump going bad?
Foam in a fluid like you are describing is basically just an idicator that there is indeed a leak as you mentioned or at best air in the system. Seeing as you spoke like you are aware of the leak... its not just air in the system and the leak needs to be fixed. If you let it go and lose more fluid and keep running the air through the system then THAT can result in a burnt up pump.
I suggest tracing down the leak, fixing it, and draining all fluid and pulling a vacuum on the system with a MityVac or something similar to ensure all the air is out of the system...then replace with clean fluid. Otherwise you run the risk of getting a whining sound in your pump and burning it up, costing a good bit more that an easy line fix if your leak is along that lines. A hand pump vacuum puller doesn't run you too much and are pretty handy to have around.
Hope this helps!
