Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: Creedmoor on April 19, 2023, 01:13:42 PM
Finally found a junk yard with a couple Pintos. One of which was a 2.3 with the outer timing cover still there. That’s what I needed. Pulled the bolts and….discovered that you need to pull the crank pulley to remove said cover. 70 mile round trip. :-\ So, two questions:
Is it true you need to pull crank pulley to get the outer cover off?
How hard are these pulleys to remove? Been sitting there for a loooong time. Spray lube, impact, pry bars, three jaw puller? Any tips or advice appreciated!
Thanks.
I 'VE NEVER HAD TO REMOVE PULLEY TO GET THE COVER OFF.YOU HAVE TO FENAGLE IT A LITTLE TO FIND THE SWEET SPOT AROUND BRACKETS .PULLEY IS NOT PRESSED ON .
If the junkyard allows it, bring a Mapp Gas torch. You may need heat to get the pulley off. Mine took a lot of persuasion to get off. In the end, the heat did the trick. I don't think you need to take the pulley off but it may make it easier to get the timing cover off in the long run.
Think a regular propane torch would work? Don’t have a Mapp one and I’m not gonna even try to haul the oxy / acetylene rig down there.
I'm not sure if the propane torch would be hot enough. The pulley has been on the snout for over 40 years so it might take a bit to free it up. If that's all I had, I would give it a try.
