Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: slowride on November 17, 2013, 08:50:03 PM
The 2.3 in the wagon is the original with over 150k on it and is showing it's age. When I had the head off and cammed it I noticed there was a pretty good size ridge, so decided to build a spare and have it ready. Picked this long block up from Fred and got lucky.... I was looking for a short block to throw new bearings in and re-ring it. The head was still on so I couldn't check the bores, but had a hunch about this one. Tore it down after getting it home and found it was VERY recently rebuilt with a 1mm bore and freshly turned crank. The bearings are like brand new, so will be re-used. Took a ball hone to the bores and am re-ringing it. The reason it was using oil was the rings didn't seat due to the rebuilder using chrome rings.
Sounds like you scored a good one congrats, rings didn't seat because of the rings they didn't hone it for chrome rings, don't want that anyhow that's for extreme dirt environment chrome rings wear out cylinder walls quick.
This is about as far as I can go without pulling the original and swapping parts.....
Looks good..
Looks like I got this done just in time. I think I put the old engine out of it's misery this morning....... :(
Pulled the old engine today and started tearing it down. Got it down to the short block and spun the crank. Number 2 (the cylinder I've had issues with) makes an odd squeaking sound when spun. I'd be willing to bet it broke a ring or two......
Pics tomorrow, and hopefully I get the new block assembled and installed.
That sucks, could be a spun bearing too??..
It had great oil pressure, and the sound is like part of a ring dragging as the piston moves. I guess it doesn't much matter as it's just a big heavy boat anchor now. After 40 years and over 150k miles, it's done well.......
Hmmm I doubt it, it's probably very rebuildable.
Yes on the rebuild. I'd love to find a 2.0 EAO to rebuild for my wagon. Did a nice head job on it and now have a rod knock and only 96K miles.
what you pulled out of the car if not damaged is what we like to call a seasoned block.....
I think I found the problem with #2 :o . The block is definitely bore-able, and the crank looks quite good for the mileage. Anyone want a screamin' deal on 2.3 engine core parts?
Bummer, where you located at??..
Anaheim, CA. Once the new engine's in and sorted out, the old engine is in the way and will have to go. I need what room I have for building the '31........ this little diversion didn't happen at a real opportune time, but at least I got to it before IT decided when.
Anaheim huh, I'm at the river I could probably get it out here maybe, let me know when you're ready to part with it I wouldn't mind having it, it is a complete motor, right?..
It's missing minor pieces.... pan, crank pulley, etc, but head and short block complete. We have a river place in Bullhead and will be headed out in a few weeks if it makes it easier.
I'm in Parker that's not too bad.
I may be slow, but I do things a certain way and get it done eventually. This was this morning on the engine stand. Dropped it in today and am ready to fire tomorrow. Here's hoping for a good Thanksgiving!
Looks good, good luck.
Love the smell of a new engine at Thanksgiving.. .. Just makes everything seem ok... Nice engine. Really nice..
SLOWRIDE! Get a Merkur air condition mount, and you can use it to mount the alternator on the right side of the engine. Then you can work on the distributor with nothing in your way.
It's all good... I found the right size shoe horn and assembly/dis-assembly sequence. Out to go finish it up and fire it. Cross your fingers folks.....
Well, it's done and have a few miles on it. No leaks, runs great, idles smooth...... wife says it's like a new car. I'm sure a good part of the smoothness is the new motor mounts, too. Well worth the time and (minimal) money.
Congrats,glad to hear it all turned out good.
74PW, sent you a PM, but not sure it went thru.
Got it and back at ya. ;)
Put a few miles on it this weekend and can feel the power increasing as the rings seat. Thought I'd clean her up a little and show a little love. 8)
VERY NICE RIDE!!!! Love that color.
VERY nice.. 8) 8)
