Refresh History
  • dave1987: hey fred
    Today at 02:27:26 PM
  • Starsky and Hutch: me too
    Today at 12:50:58 PM
  • Carolina Boy: That's what I think happened.
    Today at 12:30:48 PM
  • Starsky and Hutch: did someone hack the site again
    Today at 10:06:39 AM
  • pintosopher: Get your Muse out of the cupboard, Find a Limerick  :lol:
    Today at 10:00:19 AM
  • pintosopher: Friday's here, get another case o Beer!
    Today at 09:39:06 AM
  • Starsky and Hutch: yea get to it
    Today at 09:36:51 AM
  • pintosopher: Tanks for Da memories!
    Today at 09:35:39 AM
  • Fred Morgan: It's a good morning for baking fuel tank's  ;D
    Today at 09:34:17 AM
  • pintosopher: bueno pollo Loco!
    Today at 09:33:52 AM
  • pintogirl: Good Morning!
    Today at 09:00:36 AM
  • Starsky and Hutch: morning everyone
    Today at 08:52:17 AM
  • dga57: Good-night, Mary Ellen!
    Today at 03:34:16 AM
  • blupinto: ;D ;) :sleep:
    Today at 03:33:08 AM
  • dga57: Oh... you're still here.  I had to go do a quick fix on the pneumatic tube system.  I'm the only one here who knows anything about it ::)
    Today at 03:32:46 AM
  • dga57: Good-night, Becky! :sleep:
    Today at 03:32:05 AM
  • blupinto: Dwayne's probably looking for coffee ice cream in the hospital cafeteria. :lol:
    Today at 03:31:55 AM
  • blupinto: Nite Dave. Nite Dwayne. :sleep:
    Today at 03:31:19 AM
  • blupinto: Never mind. :P
    Today at 03:30:43 AM
  • blupinto: There you go! Was yours the original cap for your '78?
    Today at 03:30:12 AM
Found on Craigslist AZ --
Date: 02/24/2010 11:12 pm
Comments (0)
1973 Ford V-8 Pinto Hatchback
Date: 02/26/2010 03:27 pm
Comments (0)
1971-74 Ford Pinto 2.0 Liter NOS Oil Pan
Date: 01/22/2010 06:51 pm
Comments (0)
1980 Hatchback For Sale
Date: 02/13/2010 08:25 am
Comments (1)
Tan Arm Rests $20
Date: 01/18/2010 12:44 pm
Comments (0)
Pinto Wagon Sport Mirrors Both Pass and drivers side
Date: 01/23/2010 07:02 pm
Comments (0)
1976 Ford Pinto
Date: 01/15/2010 11:28 am
Comments (3)
1974 Pinto 2 door 2.0 4 spd
Date: 02/28/2010 06:25 pm
Comments (0)
71 Pinto Sedan
Date: 03/02/2010 01:03 am
Comments (2)
NOS Hood Pad Insulator
Date: 02/14/2010 10:12 am
Comments (0)
Make a Monster!
Date: 01/27/2010 11:06 am
Comments (4)
Pinto consoles
Date: 01/31/2010 11:10 pm
Comments (1)
Author Topic: 8"rear whine  (Read 158 times)
Offline Pangra74
  • PCCA Polo Shirt Vendor
  • PCCA Charter Member
  • Pinto Full Member
  • FeedBack: +1/-0
  • Gender: Male
  • I'm gettin' a V8 this summer!!
8"rear whine
« on: February 07, 2010, 10:44:42 PM »
Well,
I finally got my Mustang II 8" rear bolted in. Yes it was a pretty easy swap. I noticed that it pushed my driveshaft a little farther into my T5, but still has about 1/2" to 3/4" clearance, and doesn't touch the tail housing of the trans. I filled it up with gear oil, fired it up and this thing sings a high pitched whine, louder and higher as the rpm's increase. The only thing I did to this rear was change the pinion seal and was careful not to overtighten the pinion nut (which was not very tight when I took it off). Have any of you had a singing rear like this. It kinda goes SSHHEEEEEEEEE and when you let it slow back down it's like a SSHHeeeeowwwww . Pinion bearing worn out? Obviously the rear was used, so I had no idea if it had any problems or what kind of mileage is on it. I need to have this thing up and running for Knotts in April.
Joe
Offline pintosopher
  • PCCA VIP
  • Pinto Sr. Member
  • FeedBack: +4/-0
  • Gender: Male
  • Esses are My Nirvana, Pintosophy - my Mission
Re: 8"rear whine
« Reply #1 on: February 08, 2010, 08:51:15 AM »
Joe ,
 There is a non-reusable Crush sleeve in the Pinion shaft bearing area that must be replaced when you loosen the Pinion nut for any reason. The Crush amount is linked to the tightening torque, so the Nut might not have felt tight when you removed it. Re-tightening the nut would overload the pinion bearings and cause the squeal. Pull the center section and do a bench rebuild or have a rear gear shop do a reset and lash adjust with new crush sleeve.  Time for Limited slip too?
 Good luck ..
Yes , it is possible to study and become a master of Pintosophy... Not a religion , nothing less than a life quest for non conformity and rational thought
Offline Pangra74
  • Pinto Full Member
  • FeedBack: +1/-0
  • Gender: Male
Re: 8"rear whine
« Reply #2 on: February 08, 2010, 02:10:02 PM »
I'm pulling the third member today and having it rebuilt. The guy says it shouldn't be too bad. I definitely wasn't going to run it anymore until it was fixed. I didn't want metal parts flying around in there!!
Joe
Offline Pangra74
  • Pinto Full Member
  • FeedBack: +1/-0
  • Gender: Male
Re: 8"rear whine
« Reply #3 on: February 10, 2010, 04:43:03 PM »
Well, as I suspected the differential guy found bad pinion bearings in the rear, so about $150 will solve that problem.
